Ir para o conteúdo principal
Toshiba Satellite S55t-A5389 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite S55t-A5389 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Flip laptop over so that the bottom is facing upwards.
    • Remove the two 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite S55t-A5389 Keyboard Replacement: passo 2, imagem 2 %32
    • Flip the laptop over and open the display.
    • Insert a plastic opening tool into the gap found between the keyboard and top case.
    • Pry upwards until you hear a click and work your way around the perimeter of the keyboard.
  3. Toshiba Satellite S55t-A5389 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite S55t-A5389 Keyboard Replacement: passo 3, imagem 2 %32 Toshiba Satellite S55t-A5389 Keyboard Replacement: passo 3, imagem 3 %32
    • Lift the keyboard up, but not all the way since there's a ribbon cable attached underneath.
    • Underneath the keyboard is a ribbon cable that attaches it to the rest of the laptop.
    • Unlock the ribbon cable by lifting up the two small locks on both sides of the connector on the motherboard.
    • Once unlocked, remove the ribbon cable and keyboard from the laptop.
Conclusão
3 outras pessoas executaram este guia.
William Mazanec
Membro desde: 01/29/18
1.374 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team S5-G6, Passmore Spring 2018 Membro de USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Membros
Autoria de 8 guias
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 634
