Ir para o conteúdo principal
Toshiba Satellite S55T-B5335 Wi-Fi Adapter Replacement
O que você precisa
  1. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Battery: passo 1, imagem 1 %32
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 2, imagem 1 %32 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 2, imagem 2 %32 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 2, imagem 3 %32
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: passo 3, imagem 1 %32 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: passo 3, imagem 2 %32
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 4, imagem 1 %32
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 5, imagem 1 %32
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Wi-Fi Adapter: passo 6, imagem 1 %32
    • Using the pointed end of the Spudger, gently disconnect the antenna (white and black wires) from the Wi-Fi adapter.
  7. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 7, imagem 1 %32
    • Remove the single 4 mm Phillips #1 screw holding the Wi-Fi adapter in place.
  8. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: passo 8, imagem 1 %32
    • While grabbing the Wi-Fi adapter on both sides, gently pull away from the socket in the direction of the removed screw.
Conclusão
Uma outra pessoa concluiu este guia.
George Gillespie
Membro desde: 09/15/16
721 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 2-1, Blackwell Fall 2016 Membro de USF Tampa, Team 2-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G1
4 Membros
Autoria de 7 guias
Um comentário
George, do you know where the graphics chip is at on that motherboard?
Any Where - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 1,260
