Ir para o conteúdo principal
Toshiba Satellite S55T-B5335 Cooling Fans Replacement
O que você precisa
  1. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Battery: passo 1, imagem 1 %32
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: passo 2, imagem 1 %32 Toshiba Satellite S55T-B5335 Cooling Fans Replacement: passo 2, imagem 2 %32 Toshiba Satellite S55T-B5335 Cooling Fans Replacement: passo 2, imagem 3 %32
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Bottom Cover: passo 3, imagem 1 %32 Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Bottom Cover: passo 3, imagem 2 %32
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: passo 4, imagem 1 %32
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: passo 5, imagem 1 %32
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Cooling Fans: passo 6, imagem 1 %32
    • Remove the two 3.5 mm Phillips #1 screws that hold the cooling fan in place.
  7. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: passo 7, imagem 1 %32
    • Wedge the flat end of the spudger between the connector and its socket.
    • Twist back and forth in order to pry the connector loose from its socket.
    • Although you can pull on the connector wires to remove it from the socket, it is not recommended until the connector is loose to prevent damage to the wires.
  8. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: passo 8, imagem 1 %32
    • Lift up on the cooling fan to remove it from the laptop.
    • Repeat steps 6-8 for the other cooling fan.
Conclusão
Uma outra pessoa concluiu este guia.
George Gillespie
Membro desde: 09/15/16
721 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 2-1, Blackwell Fall 2016 Membro de USF Tampa, Team 2-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G1
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 1,531
