Ir para o conteúdo principal
Toshiba Satellite S50-B Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite S50-B Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite S50-B Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite S50-B Hard Drive Replacement: passo 2, imagem 2 %32
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • Locate the 12 screws on the bottom of the device. Unscrew using a Phillips screwdriver, and set screws aside.
    • Use a plastic opening tool to remove bottom casing.
  4. Toshiba Satellite S50-B Hard Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite S50-B Hard Drive Replacement: passo 4, imagem 2 %32
    • Use the plastic casing over the hard drive to lift the hard drive up.
    • Once hard drive is slightly lifted up, make sure the laptop is in correct orientation with the battery away from you, and pull the hard drive towards right.
Conclusão
4 outras pessoas executaram este guia.
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 27
Duração total: 6,015
