Introdução
A guide to replace the SUB/SD card/headphone jack within your Toshiba Radius.
Ferramentas
Não são necessárias ferramentas.
Peças
Não são necessárias peças.
  1. Turn off the laptop before starting.
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Remove the twelve M2x4mm PH0 Philips head screws.
    • Remove the twelve M2x4mm PH0 Philips head screws.
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
    • Unscrew the two screws holding the panel of the UBS/SD card/headphone jack
    • disconnect the cable shown from the motherboard
    • disconnect the cable attached to the top of the USB/SD card/headphone jack interface
    • remove the interface
Conclusão
Garrett barta
101 reputação
Autoria de 1 guia
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Todo: 134
