Ir para o conteúdo principal
Toshiba Satellite Radius P55W-B5220 Motherboard Replacement
O que você precisa
  1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Using the plastic opening tool, remove the two rubber feet closest to the hinge.
  2. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the 12 M2x4mm PH0 Philips screws.
  3. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 3, imagem 1 %32
    • Near the hinges, wedge a plastic opening tool under the back panel.
  4. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 4, imagem 1 %32
    • Unlatch the LED indicator from the back panel.
  5. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 5, imagem 1 %32
    • Using a P0 Philips head screwdriver, Remove the four M2x2.5mm P0 Philips screws from the battery.
  6. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 6, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 6, imagem 2 %32
    • Lift the battery.
    • Disconnect the battery.
  7. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 7, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 7, imagem 2 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 7, imagem 3 %32
    • Disconnect the ribbon cable of the touchpad from the motherboard.
  8. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 8, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the two M2x2.5mm P0 Philips screws from the fan.
  9. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 9, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 9, imagem 2 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 9, imagem 3 %32
    • Disconnect the fan cables.
    • Carefully unhook the wires from the base of the fan.
  10. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 10, imagem 1 %32
    • Unscrew the four M2x4mm PH0 Philips screws from the CPU mounts on the motherboard.
  11. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 11, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 11, imagem 2 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 11, imagem 3 %32
    • Carefully lift the heatsink off the CPU.
    • Avoid bending or kinking the tubing.
    • Delicately lift the fan out with the heatsink.
  12. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 12, imagem 1 %32
    • Remove the M2x2.5mm P0 Philips screw from the USB controller.
  13. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 13, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 13, imagem 2 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 13, imagem 3 %32
    • Lift the USB controller from the motherboard.
    • Detach the USB controller from the motherboard.
  14. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 14, imagem 1 %32
    • Disconnect the left speaker from the motherboard.
  15. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 15, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 15, imagem 2 %32
    • Remove the two M2x4mm PH0 Philips screws for the speaker mounts.
  16. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 16, imagem 1 %32
    • Unhook the speaker from under the hinge cable mounts.
  17. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 17, imagem 1 %32
    • Unhook the right speaker cable from the motherboard.
  18. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 18, imagem 1 %32
    • Remove the copper tape from the speaker cord.
  19. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 19, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 19, imagem 2 %32
    • Unhook the speaker cables from under the catch under the hinge.
  20. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 20, imagem 1 %32
    • Remove the eight M2x2.5mm P0 Philips screws from the motherboard.
  21. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: passo 21, imagem 1 %32
    • Remove the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 1,748
