Ir para o conteúdo principal
Toshiba Satellite Radius P55W-B5220 Battery Replacement
O que você precisa
  1. Toshiba Satellite Radius P55W-B5220 Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 Battery Replacement: passo 2, imagem 1 %32
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 Battery Replacement: passo 3, imagem 1 %32
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 Battery Replacement: passo 4, imagem 1 %32
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 Battery Replacement, Battery: passo 5, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 Battery Replacement, Battery: passo 5, imagem 2 %32
    • Remove the four M2x2.5mm P0 Philips head screws.
  6. Toshiba Satellite Radius P55W-B5220 Battery Replacement: passo 6, imagem 1 %32 Toshiba Satellite Radius P55W-B5220 Battery Replacement: passo 6, imagem 2 %32
    • Pinch the attached cables and carefully pull away to remove the battery.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 2,774
