Ir para o conteúdo principal
Toshiba Satellite R15-S829 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite R15-S829 Hard Drive Replacement, Battery Replacement: passo 1, imagem 1 %32
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite R15-S829 Hard Drive Replacement: passo 2, imagem 2 %32 Toshiba Satellite R15-S829 Hard Drive Replacement: passo 2, imagem 3 %32
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Hard Drive Replacement, Hard Drive Replacement: passo 3, imagem 1 %32
    • First, begin by locating the spot of the cover of the hard drive located on the bottom of the laptop.
  4. Toshiba Satellite R15-S829 Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the screw of the cover.
  5. Toshiba Satellite R15-S829 Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite R15-S829 Hard Drive Replacement: passo 5, imagem 2 %32
    • Locate the indent where the hard drive can be removed. Remove the cover.
  6. Toshiba Satellite R15-S829 Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite R15-S829 Hard Drive Replacement: passo 6, imagem 2 %32
    • Remove the hard drive using your hand.
  7. Toshiba Satellite R15-S829 Hard Drive Replacement: passo 7, imagem 1 %32 Toshiba Satellite R15-S829 Hard Drive Replacement: passo 7, imagem 2 %32 Toshiba Satellite R15-S829 Hard Drive Replacement: passo 7, imagem 3 %32
    • Now remove the power ribbon from the hard drive.
  8. Toshiba Satellite R15-S829 Hard Drive Replacement: passo 8, imagem 1 %32
    • Locate the screws on each side of the encasing of the hard drive.
  9. Toshiba Satellite R15-S829 Hard Drive Replacement: passo 9, imagem 1 %32 Toshiba Satellite R15-S829 Hard Drive Replacement: passo 9, imagem 2 %32
    • Use your Phillips screwdriver to remove the screws and be careful not to lose the screws.
  10. Toshiba Satellite R15-S829 Hard Drive Replacement: passo 10, imagem 1 %32
    • Remove the encasing from the hard drive.
Conclusão
Mike Strother
Membro desde: 10/20/16
299 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-8, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-8, Martin Fall 2016
UMASSD-MARTIN-F16S5G8
3 Membros
Autoria de 5 guias
Um comentário
cual es el numero de parte del flex porfa
Alex De santiago - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 448
