Ir para o conteúdo principal
Toshiba Satellite P855-S5312 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: passo 2, imagem 2 %32 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: passo 2, imagem 3 %32
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
Conclusão
To reassemble your device, plug the ribbon into circuit board and snap the replacement keyboard in place.
Dalton
Membro desde: 10/02/17
215 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S10-G2, Thompson Fall 2017 Membro de USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,253
