Ir para o conteúdo principal
Toshiba Satellite P855-S5312 Hinge Replacement
O que você precisa
  1. Toshiba Satellite P855-S5312 Hinge  Replacement, Fan: passo 1, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement, Fan: passo 1, imagem 2 %32 Toshiba Satellite P855-S5312 Hinge  Replacement, Fan: passo 1, imagem 3 %32
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  2. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 2, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 2, imagem 2 %32
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  3. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 3, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 3, imagem 2 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 3, imagem 3 %32
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  4. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 4, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 4, imagem 2 %32
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  5. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 5, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 5, imagem 2 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 5, imagem 3 %32
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
  6. Toshiba Satellite P855-S5312 Hinge  Replacement, Screen: passo 6, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement, Screen: passo 6, imagem 2 %32 Toshiba Satellite P855-S5312 Hinge  Replacement, Screen: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Turn laptop upside down with the spine facing towards you and locate the microchip.
    • Remove the white and black sliding connector wires by prying upward with tweezers gently pulling the black and white wires upwards.
  7. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 7, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 7, imagem 2 %32
    • Unplug the single ZIF connector ribbon by gently pulling up.
    • Pull the white and black wires through from the underside of device.
  8. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 8, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 8, imagem 2 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 8, imagem 3 %32
    • Unscrew the four hinges mounting the 1.5mm screws on each side from casing using a Philips #0 screwdriver.
    • Remove entire screen assembly from casing.
  9. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 9, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 9, imagem 2 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 9, imagem 3 %32
    • Locate the two black sticker covers on the bottom of both sides of the monitor
    • Using a pair of tweezers, carefully remove black stickers concealing two screws
  10. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 10, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 10, imagem 2 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 10, imagem 3 %32
    • Using a prying tool, carefully pry along the edges of the screen cover
  11. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 11, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 11, imagem 2 %32
    • Unscrew the two 1.5mm screws at the bottom of monitor using a Philips #0 screwdriver.
  12. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 12, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 12, imagem 2 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 12, imagem 3 %32
    • With all the edges of the screen cover pried up, carefully remove the screen cover.
  13. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 13, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 13, imagem 2 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 13, imagem 3 %32
    • Using the Philips #0 screwdriver, remove the four 1.5mm screws at the corners of the screen.
  14. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 14, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 14, imagem 2 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 14, imagem 3 %32
    • At the top of the screen, using the tweezers, remove the ZIF ribbon connector by gently pushing it up.
  15. Toshiba Satellite P855-S5312 Hinge  Replacement: passo 15, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement: passo 15, imagem 2 %32
    • Remove the screen from the device.
    • Make sure to be carful because the screen is very fragile.
  16. Toshiba Satellite P855-S5312 Hinge  Replacement, Hinge: passo 16, imagem 1 %32 Toshiba Satellite P855-S5312 Hinge  Replacement, Hinge: passo 16, imagem 2 %32 Toshiba Satellite P855-S5312 Hinge  Replacement, Hinge: passo 16, imagem 3 %32
    • Remove the three screws on the sides of the screen using the Philips #0 screwdriver.
    • Once unscrewed, pull the frame off along with the hinge.
Conclusão
James Wiehle
Membro desde: 10/02/17
236 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S10-G2, Thompson Fall 2017 Membro de USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,717
