Ir para o conteúdo principal
Toshiba Satellite P855-S5312 Fan Replacement
O que você precisa
  1. Toshiba Satellite P855-S5312 Fan Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite P855-S5312 Fan Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite P855-S5312 Fan Replacement, Battery: passo 1, imagem 3 %32
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: passo 2, imagem 1 %32 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: passo 2, imagem 2 %32 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: passo 2, imagem 3 %32
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
  3. Toshiba Satellite P855-S5312 Fan Replacement, Fan: passo 3, imagem 1 %32 Toshiba Satellite P855-S5312 Fan Replacement, Fan: passo 3, imagem 2 %32 Toshiba Satellite P855-S5312 Fan Replacement, Fan: passo 3, imagem 3 %32
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  4. Toshiba Satellite P855-S5312 Fan Replacement: passo 4, imagem 1 %32 Toshiba Satellite P855-S5312 Fan Replacement: passo 4, imagem 2 %32
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  5. Toshiba Satellite P855-S5312 Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite P855-S5312 Fan Replacement: passo 5, imagem 2 %32 Toshiba Satellite P855-S5312 Fan Replacement: passo 5, imagem 3 %32
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  6. Toshiba Satellite P855-S5312 Fan Replacement: passo 6, imagem 1 %32 Toshiba Satellite P855-S5312 Fan Replacement: passo 6, imagem 2 %32
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  7. Toshiba Satellite P855-S5312 Fan Replacement: passo 7, imagem 1 %32 Toshiba Satellite P855-S5312 Fan Replacement: passo 7, imagem 2 %32 Toshiba Satellite P855-S5312 Fan Replacement: passo 7, imagem 3 %32
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
Conclusão
Dalton
Membro desde: 10/02/17
215 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S10-G2, Thompson Fall 2017 Membro de USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 560
