Ir para o conteúdo principal
Toshiba Satellite P855-S5312 Disk Drive Replacement
O que você precisa
  1. Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: passo 1, imagem 3 %32
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: passo 2, imagem 1 %32 Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: passo 2, imagem 2 %32
    • Once laptop is turned over with the spine facing you, locate the large L shape panel.
    • Using a Philips #0 screwdriver unscrew the 1.5mm screw towards the bottom of the laptop.
  3. Toshiba Satellite P855-S5312 Disk Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite P855-S5312 Disk Drive Replacement: passo 3, imagem 2 %32
    • Open the motherboard access cover.
  4. Toshiba Satellite P855-S5312 Disk Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite P855-S5312 Disk Drive Replacement: passo 4, imagem 2 %32
    • Using a Philips #0 screwdriver, unscrew the 1.5mm screw located near the left edge of the opening near the mother board.
  5. Toshiba Satellite P855-S5312 Disk Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite P855-S5312 Disk Drive Replacement: passo 5, imagem 2 %32
    • Gently pull the entire disk drive assembly out.
  6. Toshiba Satellite P855-S5312 Disk Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite P855-S5312 Disk Drive Replacement: passo 6, imagem 2 %32 Toshiba Satellite P855-S5312 Disk Drive Replacement: passo 6, imagem 3 %32
    • Flip your device over and rotate the side of the optical drive over to you.
    • Unclip the clips on the side of the automatic release.
    • Use a paper clip or small needle tool to insert in the manual release located on the right of the automatic release button.
    • Once released slide the aluminum case out.
Conclusão
Bishop Clark
Membro desde: 10/02/17
225 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S10-G2, Thompson Fall 2017 Membro de USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 516
