Ir para o conteúdo principal
Toshiba Satellite P855-S5102 Laptop Screen Replacement
O que você precisa
  1. Toshiba Satellite P855-S5102 Laptop Screen Replacement, Laptop Screen: passo 1, imagem 1 %32 Toshiba Satellite P855-S5102 Laptop Screen Replacement, Laptop Screen: passo 1, imagem 2 %32
    • Remove the two F3 screws on the bottom part of the screen.
  2. Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 2, imagem 1 %32 Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, carefully pry open the border of the screen away from the screen until the border is completely off.
  3. Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 3, imagem 1 %32 Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 3, imagem 2 %32 Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 3, imagem 3 %32
    • Using the Phillips 001, carefully remove each F3 screw on each corner of the screen.
  4. Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 4, imagem 1 %32 Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 4, imagem 2 %32 Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 4, imagem 3 %32
    • Using the Phillips 012, remove the three F2 screws on each side of the screen.
  5. Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 5, imagem 1 %32 Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 5, imagem 2 %32
    • Carefully lift up the screen for an easier removal of the webcam. Then gently remove the connector by sliding it out of the webcam.
  6. Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 6, imagem 1 %32 Toshiba Satellite P855-S5102 Laptop Screen Replacement: passo 6, imagem 2 %32
    • Remove the tape holding the sliding connector and gently pull it out.
Conclusão
Rodrigo
Membro desde: 01/25/18
133 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S20-G3, Passmore Spring 2018 Membro de USF Tampa, Team S20-G3, Passmore Spring 2018
USFT-PASSMORE-S18S20G3
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 303
