Ir para o conteúdo principal
Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement
O que você precisa
  1. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Battery: passo 1, imagem 1 %32
    • First flip the device over so that the back side is facing upwards
  2. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 2, imagem 1 %32
    • Push the two sliders toward the edge of the laptop.
    • Remove the battery.
  3. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Display Assembly: passo 3, imagem 1 %32
    • Open the lid.
  4. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 4, imagem 1 %32 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 4, imagem 2 %32 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 4, imagem 3 %32
    • Remove the four screw covers in each of the four corners of the screen.
  5. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 5, imagem 1 %32 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 5, imagem 2 %32 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 5, imagem 3 %32
    • Remove the 4 screws in each of the 4 corners.
  6. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 6, imagem 1 %32 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 6, imagem 2 %32 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 6, imagem 3 %32
    • Take your prying tool and proceed to pry the screen cover off and set to the side.
  7. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 7, imagem 1 %32
    • Disconnect the wire from the camera and the backside of the display assembly.
  8. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 8, imagem 1 %32 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 8, imagem 2 %32 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: passo 8, imagem 3 %32
    • Remove the 6 screws holding the display assembly and holding brackets together.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 100
