Ir para o conteúdo principal
Toshiba Satellite P755 S5390 Touchpad Repair
O que você precisa
  1. Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: passo 1, imagem 1 %32 Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: passo 1, imagem 2 %32 Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: passo 1, imagem 3 %32
    • Make sure that your laptop is powered off before starting.
    • Close the cover and turn the laptop over so that the spine is facing away from you.
  2. Toshiba Satellite P755 S5390 Touchpad Repair: passo 2, imagem 1 %32 Toshiba Satellite P755 S5390 Touchpad Repair: passo 2, imagem 2 %32
    • Slide and hold the locks on both sides of the battery to the unlocked position.
    • Slide and lift the battery out of its compartment.
  3. Toshiba Satellite P755 S5390 Touchpad Repair: passo 3, imagem 1 %32
    • Use the Philips #1 screwdriver to remove the 15 screws from the base of the laptop.
    • Keep track of these screws, you will need them in reassembly.
  4. Toshiba Satellite P755 S5390 Touchpad Repair: passo 4, imagem 1 %32
    • Turn the laptop back over.
    • Open the cover.
  5. Toshiba Satellite P755 S5390 Touchpad Repair: passo 5, imagem 1 %32 Toshiba Satellite P755 S5390 Touchpad Repair: passo 5, imagem 2 %32 Toshiba Satellite P755 S5390 Touchpad Repair: passo 5, imagem 3 %32
    • Using either the iFixit opening tool or your hands, gently remove the keyboard from the base panel.
    • Do not touch the motherboard.
  6. Toshiba Satellite P755 S5390 Touchpad Repair: passo 6, imagem 1 %32 Toshiba Satellite P755 S5390 Touchpad Repair: passo 6, imagem 2 %32
    • Check if the touch pad cable is plugged into the ZIF connector on the motherboard.
  7. Toshiba Satellite P755 S5390 Touchpad Repair: passo 7, imagem 1 %32 Toshiba Satellite P755 S5390 Touchpad Repair: passo 7, imagem 2 %32 Toshiba Satellite P755 S5390 Touchpad Repair: passo 7, imagem 3 %32
Conclusão
5 outras pessoas executaram este guia.
Dominic Oldani
Membro desde: 03/19/16
237 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 6,711
