Ir para o conteúdo principal
Toshiba Satellite P75-A7100 Fan Replacement
O que você precisa
  1. Toshiba Satellite P75-A7100 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Slide the tabs apart from each other.
  2. Toshiba Satellite P75-A7100 Fan Replacement: passo 2, imagem 1 %32 Toshiba Satellite P75-A7100 Fan Replacement: passo 2, imagem 2 %32
    • Lift the battery upwards and remove it from the device.
  3. Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: passo 3, imagem 1 %32 Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: passo 3, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the screw from the back cover.
    • Remove the back cover from the device.
  4. Toshiba Satellite P75-A7100 Fan Replacement: passo 4, imagem 1 %32 Toshiba Satellite P75-A7100 Fan Replacement: passo 4, imagem 2 %32 Toshiba Satellite P75-A7100 Fan Replacement: passo 4, imagem 3 %32
    • Remove the optical drive from the device.
  5. Toshiba Satellite P75-A7100 Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite P75-A7100 Fan Replacement: passo 5, imagem 2 %32
    • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
    • Remove the back cover from your device.
  6. Toshiba Satellite P75-A7100 Fan Replacement: passo 6, imagem 1 %32 Toshiba Satellite P75-A7100 Fan Replacement: passo 6, imagem 2 %32 Toshiba Satellite P75-A7100 Fan Replacement: passo 6, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
    • Remove the Wi-Fi adapter from the device.
  7. Toshiba Satellite P75-A7100 Fan Replacement, Fan: passo 7, imagem 1 %32 Toshiba Satellite P75-A7100 Fan Replacement, Fan: passo 7, imagem 2 %32
    • Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan.
    • Unplug the connector connecting the fan to the motherboard.
    • Remove the fan from the device.
Conclusão
Um comentário
How do you remove and replace the fan from from/to the heatsink? Mine is secured with a metallic tape that is not sticky once removed.
Bruce - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 2,366
