Introdução
Use this guide to remove the Toshiba Satellite P55t-A5116 RAM.
O que você precisa
Ferramenta utilizada neste passo:Tweezers$4.99
Close laptop and turn it upside down
Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
Locate the RAM cover on the back of the Laptop.
Using the #PH0 screw head, remove 1 (5.7mm) screw.
Use the plastic opening tool to remove the RAM cover.
1Comentário do guia
I’m confused… it only seems like Step 4 and Step 5 are necessary. Does the battery need to be removed before replacing the RAM? If that’s why Steps 1-3 are there, there’s a lot of steps/information missing. It just goes from “take off the bottom case” to “remove the RAM cover of intact laptop”.
