Ir para o conteúdo principal
Toshiba Satellite P55t-A5116 Power Jack Replacement
O que você precisa
  1. Toshiba Satellite P55t-A5116 Power Jack Replacement, Back Casing: passo 1, imagem 1 %32 Toshiba Satellite P55t-A5116 Power Jack Replacement, Back Casing: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Power Jack Replacement: passo 2, imagem 1 %32 Toshiba Satellite P55t-A5116 Power Jack Replacement: passo 2, imagem 2 %32
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Power Jack Replacement: passo 3, imagem 1 %32 Toshiba Satellite P55t-A5116 Power Jack Replacement: passo 3, imagem 2 %32 Toshiba Satellite P55t-A5116 Power Jack Replacement: passo 3, imagem 3 %32
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 Power Jack Replacement, Battery: passo 4, imagem 1 %32 Toshiba Satellite P55t-A5116 Power Jack Replacement, Battery: passo 4, imagem 2 %32
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Power Jack Replacement: passo 5, imagem 1 %32
    • Gently remove battery from the laptop.
  6. Toshiba Satellite P55t-A5116 Power Jack Replacement, Power Jack: passo 6, imagem 1 %32 Toshiba Satellite P55t-A5116 Power Jack Replacement, Power Jack: passo 6, imagem 2 %32 Toshiba Satellite P55t-A5116 Power Jack Replacement, Power Jack: passo 6, imagem 3 %32
    • Using the #PH0 screw head, remove 2 (5.7 mm) screws.
    • Remove metal plate.
    • Using the #PH0 screw head remove 1 (5.7mm) screw and 1 (4.15mm) screw.
  7. Toshiba Satellite P55t-A5116 Power Jack Replacement: passo 7, imagem 1 %32 Toshiba Satellite P55t-A5116 Power Jack Replacement: passo 7, imagem 2 %32
    • Use the plastic opening tool to push the left hinge up.
  8. Toshiba Satellite P55t-A5116 Power Jack Replacement: passo 8, imagem 1 %32 Toshiba Satellite P55t-A5116 Power Jack Replacement: passo 8, imagem 2 %32
    • Gently pull up the power jack. Follow the cord until you reach the connector.
    • Unplug the 4 pin connector and remove from laptop
Conclusão
Um comentário
Absolutely terrific tutorial! This helped me immensely. My laptop is Toshiba Satellite P55T-5202 and has the same layout as this. This worked perfectly.
I purchased the part form Amazon, btw. Its a DC Power Jack Replacement
Alampana - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 3,829
