Ir para o conteúdo principal
Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement
O que você precisa
  1. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Back Casing: passo 1, imagem 1 %32 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Back Casing: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: passo 2, imagem 1 %32 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: passo 2, imagem 2 %32
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: passo 3, imagem 1 %32 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: passo 3, imagem 2 %32 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: passo 3, imagem 3 %32
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Battery: passo 4, imagem 1 %32 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Battery: passo 4, imagem 2 %32
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: passo 5, imagem 1 %32
    • Gently remove battery from the laptop.
  6. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Fan & CPU Cooler: passo 6, imagem 1 %32
    • Using a PH0 screwdriver, remove 2 (5.7mm) screws.
    • Using a PH0 screwdriver, remove 4 (3.68mm) screws.
  7. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: passo 7, imagem 1 %32 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: passo 7, imagem 2 %32
    • Unplug the 3 pin connector
    • Remove fan.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 20
Ao todo: 1,785
