Ir para o conteúdo principal
Toshiba Satellite P55W-C5316 Fan Replacement
O que você precisa
  1. Toshiba Satellite P55W-C5316 Fan Replacement, Back Panel: passo 1, imagem 1 %32 Toshiba Satellite P55W-C5316 Fan Replacement, Back Panel: passo 1, imagem 2 %32
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Fan Replacement: passo 2, imagem 1 %32 Toshiba Satellite P55W-C5316 Fan Replacement: passo 2, imagem 2 %32 Toshiba Satellite P55W-C5316 Fan Replacement: passo 2, imagem 3 %32
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 Fan Replacement, Fan: passo 3, imagem 1 %32
    • Remove both screws from the fan.
  4. Toshiba Satellite P55W-C5316 Fan Replacement: passo 4, imagem 1 %32 Toshiba Satellite P55W-C5316 Fan Replacement: passo 4, imagem 2 %32
    • Remove the screws securing the 4 corners of the heatsink.
    • Gently remove the heatsink. Keep in mind thermal paste is used and it may be slightly difficult to remove.
  5. Toshiba Satellite P55W-C5316 Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite P55W-C5316 Fan Replacement: passo 5, imagem 2 %32 Toshiba Satellite P55W-C5316 Fan Replacement: passo 5, imagem 3 %32
    • Remove the small, beige colored connector securing the fan to the laptop and remove the fan and heatsink assembly from the laptop.
Conclusão
Zeyad Ali
Membro desde: 11/07/19
349 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G1, Harley Fall 2019 Membro de IUPUI, Team S2-G1, Harley Fall 2019
IUPUI-HARLEY-F19S2G1
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 429
