Ir para o conteúdo principal
Toshiba Satellite P55W-C5316 Back Panel Replacement
O que você precisa
  1. Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: passo 1, imagem 1 %32 Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: passo 1, imagem 2 %32
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Back Panel Replacement: passo 2, imagem 1 %32 Toshiba Satellite P55W-C5316 Back Panel Replacement: passo 2, imagem 2 %32 Toshiba Satellite P55W-C5316 Back Panel Replacement: passo 2, imagem 3 %32
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
Conclusão
Nicholas Caswell
Membro desde: 10/19/17
117 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G2, Bailey Fall 2017
UMASSD-BAILEY-F17S3G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,014
