Ir para o conteúdo principal
Toshiba Satellite P55W-C5200X Keyboard Replacement
O que você precisa
  1. Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 2, imagem 1 %32
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 3, imagem 2 %32
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 4, imagem 2 %32
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 5, imagem 2 %32
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: passo 6, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: passo 6, imagem 2 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: passo 6, imagem 3 %32
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
  7. Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: passo 7, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: passo 7, imagem 2 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: passo 7, imagem 3 %32
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  8. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 8, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 8, imagem 2 %32
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  9. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 9, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 9, imagem 2 %32
    • Gently remove the fan from your device.
  10. Toshiba Satellite P55W-C5200X Keyboard Replacement, Keyboard: passo 10, imagem 1 %32
    • Once the fan, ram, and battery are removed, remove the motherboard.
    • Detach the three connecting wires.
    • Remove the white, blue-tipped cable ribbon too.
  11. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 11, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 11, imagem 2 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 11, imagem 3 %32
    • Remove the three wires that are connected to the motherboard first.
  12. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 12, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 12, imagem 2 %32
    • Remove the ribbon by using the black nylon spudger to avoid tearing the ribbon.
  13. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 13, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 13, imagem 2 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 13, imagem 3 %32
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal bracket in place.
    • Gently remove the metal bracket.
  14. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 14, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 14, imagem 2 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 14, imagem 3 %32
    • Use the Phillips #00 to remove the four 8.0 mm screws that are holding the motherboard in place.
    • After removing all the screws, gently remove the motherboard.
  15. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 15, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 15, imagem 2 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 15, imagem 3 %32
    • Similar to step 4, there is a metal bracket that must be removed to get to some ports.
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal plate in place.
    • Gently remove the metal bracket off the ports underneath.
  16. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 16, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 16, imagem 2 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 16, imagem 3 %32
    • Once the ports are accessible, remove four connecting wires from the ports themselves.
    • Be gentle when removing the four wires.
  17. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 17, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 17, imagem 2 %32
    • Once the connecting wires are removed, remove the 8.0 mm screw of the USB ports, using the Phillips #00 screwdriver.
    • Gently remove the USB ports.
  18. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 18, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 18, imagem 2 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 18, imagem 3 %32
    • Remove the thirty-three 1.0 mm screws with the Phillips Head #000.
    • Gently remove the metal cover.
  19. Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 19, imagem 1 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 19, imagem 2 %32 Toshiba Satellite P55W-C5200X Keyboard Replacement: passo 19, imagem 3 %32
    • Gently pull on the tab to lift the keyboard from the device.
    • Lastly remove the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 Membro de UMass Dartmouth, Team S1-G2, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G2
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 1,364
