Introdução
If your Toshiba Satellite P55W-C5200X is experiencing issues such as white spots and colored lines appearing, buzzing or random shutoffs, then it is clear your display is no longer functional. This may be due to the LED monitor, a faulty CFL monitor and/or power adapter. The best course of action is to replace the display assembly before problems become worse.
O que você precisa
Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
Use the Phillips #00 screwdriver to remove the six 5.0 mm screws that are holding the metal brackets on both sides in place.
Uma outra pessoa concluiu este guia.
