Introdução
If your Toshiba Satellite P55W-C5200X is only working when plugged into an outlet or is not detecting its battery, a look at the battery may be in order or even a replacement will be needed.
The tools needed to gain access to the battery are listed below . This is a low risk operation, the only requirement for safety is to make sure the device is turned off before starting and keeping away from liquids while working on the device. Also, be aware of swollen batteries as these can be dangerous.
This guide will tell Toshiba Satellite P55W-C5200X users how to replace a defective battery.
O que você precisa
Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
4 outras pessoas executaram este guia.
