Ir para o conteúdo principal
Toshiba Satellite P50W-C Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite P50W-C Hard Drive Replacement, Back Cover: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Hard Drive Replacement: passo 2, imagem 1 %32
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Hard Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite P50W-C Hard Drive Replacement: passo 3, imagem 2 %32
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Remove the back cover of the device.
  5. Toshiba Satellite P50W-C Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the hard drive from the device by gently pulling on the blue plastic hard drive cover.
  6. Toshiba Satellite P50W-C Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite P50W-C Hard Drive Replacement: passo 6, imagem 2 %32
    • Disconnect the hard drive from the mother board by gently pulling out the black connector.
Conclusão
Sarah Fordjour
Membro desde: 09/25/17
450 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S3-G2, Cannon Fall 2017 Membro de USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 Membros
Autoria de 7 guias
2 comentários
Can you change the touch panel of toshibasatelliteP50W-B1038.
rizwana rizi - Responder
Hi dear,
My laptop bios was crashed,
I need to radius 15 p50w-c-104 bios dump file.
can you help me please.?
labexperiance@gmail.com
thank you
Mustafa SAYIN - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 705
