Ir para o conteúdo principal
Toshiba Satellite P50W-C Fan Replacement
O que você precisa
  1. Toshiba Satellite P50W-C Fan Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Fan Replacement: passo 2, imagem 1 %32
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Fan Replacement: passo 3, imagem 1 %32 Toshiba Satellite P50W-C Fan Replacement: passo 3, imagem 2 %32
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Fan Replacement, Fan: passo 4, imagem 1 %32
    • Unscrew the two 7 mm JIS #1 head screws securing the fan to the laptop.
  5. Toshiba Satellite P50W-C Fan Replacement: passo 5, imagem 1 %32
    • Using tweezers, disconnect power cable by gently pulling white end out from its socket.
  6. Toshiba Satellite P50W-C Fan Replacement: passo 6, imagem 1 %32
    • Remove heat sink by unscrewing the four 3 mm JIS #1 head screws
  7. Toshiba Satellite P50W-C Fan Replacement: passo 7, imagem 1 %32 Toshiba Satellite P50W-C Fan Replacement: passo 7, imagem 2 %32 Toshiba Satellite P50W-C Fan Replacement: passo 7, imagem 3 %32
    • Based on the quality of the fan either the clean fan or replace the fan.
Conclusão
Uma outra pessoa concluiu este guia.
Sarah Fordjour
Membro desde: 09/25/17
450 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S3-G2, Cannon Fall 2017 Membro de USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 880
