Ir para o conteúdo principal
Toshiba Satellite P50W-C Battery Replacement
O que você precisa
  1. Toshiba Satellite P50W-C Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Battery Replacement: passo 2, imagem 1 %32
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Battery Replacement: passo 3, imagem 1 %32 Toshiba Satellite P50W-C Battery Replacement: passo 3, imagem 2 %32
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Battery Replacement, Battery: passo 4, imagem 1 %32
    • Unscrew the four 5 mm JIS #1 head screws holding the battery to the device and gently remove the battery.
  5. Toshiba Satellite P50W-C Battery Replacement: passo 5, imagem 1 %32 Toshiba Satellite P50W-C Battery Replacement: passo 5, imagem 2 %32
    • Disconnect the battery from the motherboard by gently pulling out the black connector.
Conclusão
Lawrence Lozada
Membro desde: 09/25/17
246 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S3-G2, Cannon Fall 2017 Membro de USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 943
