Ir para o conteúdo principal
Toshiba Satellite P205D-S8804 Screen Replacement
O que você precisa
  1. Toshiba Satellite P205D-S8804 Screen Replacement, Screen: passo 1, imagem 1 %32
    • With the screen on a flat surface, remove the screws in each corner of the screen. There will be 4 in total.
    • Note: The screws for the screen may be hidden under rubber pad at the top of the screen so they will have to be removed.
  2. Toshiba Satellite P205D-S8804 Screen Replacement: passo 2, imagem 1 %32
    • Using a metal spudger wedge open the front and back cover of the screen.
    • Take care to not damage the camera in the process.
  3. Toshiba Satellite P205D-S8804 Screen Replacement: passo 3, imagem 1 %32 Toshiba Satellite P205D-S8804 Screen Replacement: passo 3, imagem 2 %32
    • After the front cover is removed remove the two screws at the very bottom of the screen.
    • This will give you access to the screws running along the side of the screen.
  4. Toshiba Satellite P205D-S8804 Screen Replacement: passo 4, imagem 1 %32
    • Remove the four screws on the each side of the screen. There will be eight in total.
    • We recommend starting from the bottom and working upward.
  5. Toshiba Satellite P205D-S8804 Screen Replacement: passo 5, imagem 1 %32
    • Lay the screen flat on the keyboard so they the back panel can be accessed.
    • Remove all the tape on the video cable that connects the screen to the computer.
  6. Toshiba Satellite P205D-S8804 Screen Replacement: passo 6, imagem 1 %32
    • Remove the video cable from the screen.
    • After the video cable is removed the screen is free and can be removed from the computer.
Conclusão
Caroline Camp
Membro desde: 01/30/17
1 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 3-2, Whitney Spring 2017 Membro de Baylor, Team 3-2, Whitney Spring 2017
BU-WHITNEY-S17S3G2
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 113
