Ir para o conteúdo principal
Toshiba Satellite P205D-S8804 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite P205D-S8804 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Place the laptop with the screen facing you and grab the opening tool.
    • Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
    • You will feel the popping sensation as it slides along.
  2. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 2, imagem 1 %32
    • Lit up the left side of the small plastic bar at the top of the keyboard.
    • Be careful when removing it, because you will need to apply a bit of force .
  3. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 3, imagem 1 %32
    • Use a PH0 screwdriver to unscrew the 4 screws at the top of the keyboard.
  4. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 4, imagem 1 %32
    • Lift up the keyboard and pull it toward the screen.
    • The keyboard will still be connected to the motherboard by a ribbon cable.
  5. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 5, imagem 2 %32
    • To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
  6. Toshiba Satellite P205D-S8804 Keyboard Replacement: passo 6, imagem 1 %32
    • Once the ribbon is released the keyboard can be removed .
Conclusão
Caroline Camp
Membro desde: 01/30/17
1 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 3-2, Whitney Spring 2017 Membro de Baylor, Team 3-2, Whitney Spring 2017
BU-WHITNEY-S17S3G2
Membros da 4
Autoria de 4 guias
Um comentário
rename tool with a standard link for easier accessibility
Andy Feng - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 218
