Ir para o conteúdo principal
Toshiba Satellite P205D-S8804 CD Drive Replacement
O que você precisa
  1. Toshiba Satellite P205D-S8804 CD Drive Replacement, Keyboard: passo 1, imagem 1 %32
    • Place the laptop with the screen facing you and grab the opening tool.
    • Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
    • You will feel the popping sensation as it slides along.
  2. Toshiba Satellite P205D-S8804 CD Drive Replacement: passo 2, imagem 1 %32
    • Lit up the left side of the small plastic bar at the top of the keyboard.
    • Be careful when removing it, because you will need to apply a bit of force .
  3. Toshiba Satellite P205D-S8804 CD Drive Replacement: passo 3, imagem 1 %32
    • Use a PH0 screwdriver to unscrew the 4 screws at the top of the keyboard.
  4. Toshiba Satellite P205D-S8804 CD Drive Replacement: passo 4, imagem 1 %32
    • Lift up the keyboard and pull it toward the screen.
    • The keyboard will still be connected to the motherboard by a ribbon cable.
  5. Toshiba Satellite P205D-S8804 CD Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite P205D-S8804 CD Drive Replacement: passo 5, imagem 2 %32
    • To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
  6. Toshiba Satellite P205D-S8804 CD Drive Replacement: passo 6, imagem 1 %32
    • Once the ribbon is released the keyboard can be removed .
  7. Toshiba Satellite P205D-S8804 CD Drive Replacement, CD Drive: passo 7, imagem 1 %32
    • Flip the computer over with the hinge facing you.
    • Remove one screw that is located in the Toshiba lable on the bottom of the computer.
  8. Toshiba Satellite P205D-S8804 CD Drive Replacement: passo 8, imagem 1 %32
    • Flip the computer back over and push the metal tab to the right to release the CD drive from its docking port.
  9. Toshiba Satellite P205D-S8804 CD Drive Replacement: passo 9, imagem 1 %32
    • Remove the CD Drive.
Conclusão
Caroline Camp
Membro desde: 01/30/17
1 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 3-2, Whitney Spring 2017 Membro de Baylor, Team 3-2, Whitney Spring 2017
BU-WHITNEY-S17S3G2
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 152
