Ir para o conteúdo principal
Toshiba Satellite P205-S8811 RAM Replacement
O que você precisa
  1. Toshiba Satellite P205-S8811 RAM Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite P205-S8811 RAM Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite P205-S8811 RAM Replacement: passo 2, imagem 2 %32
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 RAM Replacement, RAM: passo 3, imagem 1 %32
    • Locate the RAM slot cover on the bottom of the laptop. The RAM slot cover is located near the battery slot.
  4. Toshiba Satellite P205-S8811 RAM Replacement: passo 4, imagem 1 %32
    • Using a Phillips-head screwdriver, unscrew and remove the screw holding the RAM slot cover in place.
  5. Toshiba Satellite P205-S8811 RAM Replacement: passo 5, imagem 1 %32 Toshiba Satellite P205-S8811 RAM Replacement: passo 5, imagem 2 %32
    • Lift and remove the RAM slot cover.
  6. Toshiba Satellite P205-S8811 RAM Replacement: passo 6, imagem 1 %32 Toshiba Satellite P205-S8811 RAM Replacement: passo 6, imagem 2 %32
    • To remove the first RAM chip, gently press outward on the tabs on both sides of the chip
    • The RAM chip should pop up after releasing the tabs.
  7. Toshiba Satellite P205-S8811 RAM Replacement: passo 7, imagem 1 %32
    • Using your fingers, remove the RAM chip by gently pulling it out of the RAM slot.
  8. Toshiba Satellite P205-S8811 RAM Replacement: passo 8, imagem 1 %32 Toshiba Satellite P205-S8811 RAM Replacement: passo 8, imagem 2 %32
    • To remove the second RAM chip, repeat the previous steps
Conclusão
Davin
Membro desde: 02/03/14
271 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-8, Amido Winter 2014 Membro de Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 484
