Ir para o conteúdo principal
Toshiba Satellite P205-S8811 Monitor Replacement
O que você precisa
  1. Toshiba Satellite P205-S8811 Monitor Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Monitor Replacement: passo 2, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 2, imagem 2 %32
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Monitor Replacement, Keyboard: passo 3, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement, Keyboard: passo 3, imagem 2 %32
    • Place the head of a plastic opening tool underneath the plastic strip lining the top of the keyboard, right above the "PGUP" button.
    • Next, pull the strip up using a plastic opening tool with a light force, until it pops off.
  4. Toshiba Satellite P205-S8811 Monitor Replacement: passo 4, imagem 1 %32
    • Lightly lift from the side that was popped up earlier in order to pop the rest of the strip off of the laptop.
  5. Toshiba Satellite P205-S8811 Monitor Replacement: passo 5, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 5, imagem 2 %32
    • Use a #1 Phillips screwdriver to take out the four 4mm Phillips #1 screws that were underneath the plastic strip.
  6. Toshiba Satellite P205-S8811 Monitor Replacement: passo 6, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 6, imagem 2 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 6, imagem 3 %32
    • Be careful to not lift up on the keyboard too quickly or harshly; there is a ribbon cable connecting the keyboard and the base which may be breakable.
    • Lightly lift up on the keyboard from one of its top corners and pull it towards the screen so you can safely remove the ribbon cable.
    • At the base of the ribbon cable, there is a tiny tab that runs across the width of the connector. Flip it up. You can now pull the ribbon cable free with no resistance towards the monitor.
    • With the cable unplugged, the keyboard can be lifted away from the laptop.
  7. Toshiba Satellite P205-S8811 Monitor Replacement, Monitor: passo 7, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement, Monitor: passo 7, imagem 2 %32
    • Unscrew the 4mm Phillips #1 screw holding the hard drive cover on.
    • Place one finger underneath the tab of the hard drive cover and lift it up with medium force to take it off.
  8. Toshiba Satellite P205-S8811 Monitor Replacement: passo 8, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 8, imagem 2 %32
    • Grab the black tab attached to the hard drive and pull it to the left with a medium force until it pops out of its socket.
  9. Toshiba Satellite P205-S8811 Monitor Replacement: passo 9, imagem 1 %32
    • Remove the two 8mm Phillips #1 screws from the back side of the laptop.
  10. Toshiba Satellite P205-S8811 Monitor Replacement: passo 10, imagem 1 %32
    • Remove the four 8mm Phillips #1 screws located on the corners below the monitor.
  11. Toshiba Satellite P205-S8811 Monitor Replacement: passo 11, imagem 1 %32
    • Remove the two 4mm Phillips #1 screws located between the screws removed in the last step.
  12. Toshiba Satellite P205-S8811 Monitor Replacement: passo 12, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 12, imagem 2 %32
    • Unplug the black wire connecting the monitor to the motherboard by pulling it lightly towards you.
    • Unplug the black/red wire that also connects the monitor to the motherboard by pulling lightly away from you.
  13. Toshiba Satellite P205-S8811 Monitor Replacement: passo 13, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 13, imagem 2 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 13, imagem 3 %32
    • Remove the three colored wires (white, grey, and black) that are all connected beside each other by pulling them up lightly.
  14. Toshiba Satellite P205-S8811 Monitor Replacement: passo 14, imagem 1 %32
    • Gently pull out the wide, white wire coming from the monitor.
  15. Toshiba Satellite P205-S8811 Monitor Replacement: passo 15, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 15, imagem 2 %32
    • Use a plastic opening tool to loosen the top panel by placing the tool underneath the panel at several points and then lifting upwards with a medium force. You will know it is loose if it makes a loud clicking noise.
    • Place your fingers on the side of the panel closest to the monitor. Lift up on that side of the panel with a large amount of force in order to pry it off.
  16. Toshiba Satellite P205-S8811 Monitor Replacement: passo 16, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 16, imagem 2 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 16, imagem 3 %32
    • Remove the 8mm Phillips #1 screw located just below the large gray wire.
    • Remove the 8mm Phillips #1 screw located to the right of the left-hand speaker.
    • Remove the 4mm Phillips #1 screw located above the fan and next to the large gray wire.
  17. Toshiba Satellite P205-S8811 Monitor Replacement: passo 17, imagem 1 %32 Toshiba Satellite P205-S8811 Monitor Replacement: passo 17, imagem 2 %32
    • Remove the large gray wire that is connected to the motherboard to the right of the fan.
    • Remove the small white/grey wire that is connected at the top of the fan.
  18. Toshiba Satellite P205-S8811 Monitor Replacement: passo 18, imagem 1 %32
    • Grabbing both sides of the monitor, gently lift the it out of place and set it aside.
Conclusão
Bradley Johnson
Membro desde: 02/02/14
214 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-8, Amido Winter 2014 Membro de Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 Membros
Autoria de 7 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Ao todo: 933
