Introdução
If your hard drive is malfunctioning or if you want to replace it, this guide will show you how to take it out.
Ferramentas
Peças
Não são necessárias peças.
Flip the laptop over so the bottom is facing upward and the battery is on top.
Slide the tab below the battery to the left.
Use a #1 Phillips screwdriver to take out the 8mm Phillips #1 screw holding the hard drive panel on.
Uma outra pessoa concluiu este guia.
Um comentário
There is a missing step between 4 and 5.
- Remove the screw(s) that hold the HDD assembly in its compartment.
...only then can you move on to step 5.
