Ir para o conteúdo principal
Introdução
If your disk drive is not reading any disks or can not open, then this guide will help you quickly replace it.
Peças
Nenhum componente especificado.
  1. Flip the laptop over so the bottom is facing upward and the battery is on top. Slide the tab below the battery to the left.
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Slide and hold the tab on the right side of the battery to the right. While holding the right tab, slide the battery upward and out its socket.
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Remove the 8mm Phillips #1 screw that holds the disk drive in place.
    • Remove the 8mm Phillips #1 screw that holds the disk drive in place.
  4. Use a plastic opening tool to pry out the disk drive.
    • Use a plastic opening tool to pry out the disk drive.
  5. Once the disk drive becomes loose, slowly slide it out and set it aside. Once the disk drive becomes loose, slowly slide it out and set it aside.
    • Once the disk drive becomes loose, slowly slide it out and set it aside.
Conclusão
Bradley Johnson
Membro desde: 02/02/2014
211 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team 2-8, Amido Winter 2014 Membro de Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 Membros
7 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 335
