Ir para o conteúdo principal
Toshiba Satellite P105-S6147 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite P105-S6147 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Use the iFixit opening tool to remove the cover at the top of the keyboard.
    • Insert the tool in the small space above the keyboard and gently pry until the cover pops out of its retaining clips.
    • Repeat the prying across the top of the keyboard until the whole cover is loose.
  2. Toshiba Satellite P105-S6147 Keyboard Replacement: passo 2, imagem 1 %32
    • Gently lift the cover off the top of the keyboard.
  3. Toshiba Satellite P105-S6147 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite P105-S6147 Keyboard Replacement: passo 3, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove six 6 mm screws labeled “F4” at the top of the keyboard.
  4. Toshiba Satellite P105-S6147 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite P105-S6147 Keyboard Replacement: passo 4, imagem 2 %32 Toshiba Satellite P105-S6147 Keyboard Replacement: passo 4, imagem 3 %32
    • Use the iFixit opening tool to pry the keyboard out of its retaining clips.
    • Insert the tool into the groove surrounding the laptop and pry until the keyboard “pops” out of the laptop body.
    • Once the keyboard is free from the laptop body, gently flip the keyboard over, as seen in the third picture.
  5. Toshiba Satellite P105-S6147 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite P105-S6147 Keyboard Replacement: passo 5, imagem 2 %32
    • Lay the keyboard down on the bottom of the laptop, as seen in image one.
    • Locate the ribbon cable connecting the bottom of the keyboard to the laptop. There will be a small black and white clip securing the ribbon cable to the laptop.
    • Use the iFixit opening tool to gently open the clip, freeing the ribbon cable from the laptop body.
    • Gently remove the keyboard from the laptop body.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 16
Duração total: 278
