Ir para o conteúdo principal
Toshiba Satellite P105-S6147 Cooling Fan Replacement
O que você precisa
  1. Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: passo 1, imagem 1 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: passo 1, imagem 2 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: passo 1, imagem 3 %32
    • Begin by placing the laptop face down on a flat surface.
    • The battery is located in the bottom left hand corner of the device.
    • Slide the lock switch on the battery to the unlocked position.
    • Slide the release lever on the battery towards the lock switch. The battery should now rotate out of its dock in the laptop.
  2. Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 2, imagem 1 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 2, imagem 2 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the casing located next to the battery.
    • Using a #0 Phillips screwdriver, remove the two 4 mm screws.
    • Use the precision tweezers to disconnect the white and black wire from the device.
    • Remove the thin black wire from the device.
  3. Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 3, imagem 1 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 3, imagem 2 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 3, imagem 3 %32
    • Open the remaining casings using a #0 Phillips screwdriver.
    • Remove all visible screws on the bottom of the laptop to complete this step.
  4. Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 4, imagem 1 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 4, imagem 2 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 4, imagem 3 %32
    • Hold the back cover slightly open.
    • Use the precision tweezers to disconnect the two ribbon cables at the bottom of the laptop.
    • Open the small black clips to free the ribbon cables.
    • Remove the back cover.
  5. Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 5, imagem 2 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 5, imagem 3 %32
    • Locate the white plug in the upper right hand corner of the laptop.
    • Use the iFixit opening tools to apply even, backwards pressure to each side of the plug until the plug is free from the motherboard.
  6. Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 6, imagem 1 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 6, imagem 2 %32
    • Locate the ribbon cable on the bottom of the laptop.
    • Open the small black clip that is holding the ribbon cable.
    • Gently remove the ribbon cable with the precision tweezers.
  7. Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 7, imagem 1 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 7, imagem 2 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 7, imagem 3 %32
    • Locate the white plug next to the ribbon cable that was removed in the previous step.
    • Gently unplug the plug with your hand or the blue iFixit opening tools.
  8. Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 8, imagem 1 %32
    • Remove the motherboard from the laptop casing.
  9. Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: passo 9, imagem 1 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: passo 9, imagem 2 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: passo 9, imagem 3 %32
    • Use the precision tweezers to remove the metal cover off the top of the cooling fan. It should "pop" off with little effort.
    • Flip over the motherboard.
    • The cooling fan is now located in the upper left-hand corner of the motherboard.
  10. Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 10, imagem 1 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 10, imagem 2 %32
    • Remove the two 5 mm screws located at the bottom right of the cooling fan.
    • The cooling fan housing is now free from the motherboard.
  11. Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 11, imagem 1 %32 Toshiba Satellite P105-S6147 Cooling Fan Replacement: passo 11, imagem 2 %32
    • Locate the white plug connecting the cooling fan to the motherboard.
    • Gently pull on the plug to disconnect the cooling fan from the motherboard.
    • Remove the cooling fan from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 13
Duração total: 270
