Ir para o conteúdo principal
Toshiba Satellite M55-S135 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite M55-S135 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Start with the laptop open and the keyboard facing you.
    • Tilt the screen away from you to reduce the risk of damaging it as you remove the keyboard.
  2. Toshiba Satellite M55-S135 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite M55-S135 Keyboard Replacement: passo 2, imagem 2 %32
    • Locate the vertical seam between the speakers and the top row of keys on the keyboard.
    • Insert the tip of a nylon spudger into the seam and slowly pry up the panel.
    • Be sure to gently pry the panel to avoid damaging it or the laptop.
  3. Toshiba Satellite M55-S135 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite M55-S135 Keyboard Replacement: passo 3, imagem 2 %32
    • Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver.
  4. Toshiba Satellite M55-S135 Keyboard Replacement: passo 4, imagem 1 %32
    • Use the nylon spudger to pry up the keyboard. Start with one side and then the other.
    • Be sure to pry gently with the screwdriver to avoid damaging the keyboard and keys.
  5. Toshiba Satellite M55-S135 Keyboard Replacement: passo 5, imagem 1 %32
    • Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
    • Disconnect the keyboard cable.
    • Be sure to disconnect the cable before removing the keyboard to avoid damaging it.
Conclusão
klismann Evora
Membro desde: 03/12/14
109 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 727
