Ir para o conteúdo principal
Toshiba Satellite M55-S135 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite M55-S135 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Use the Phillips 00 screwdriver to remove the 3.62mm screw.
  2. Toshiba Satellite M55-S135 Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the plastic cover from the laptop.
  3. Toshiba Satellite M55-S135 Hard Drive Replacement: passo 3, imagem 1 %32
    • Pull the black plastic tab horizontally away from the hard drive to disconnect and remove the hard drive from the laptop.
  4. Toshiba Satellite M55-S135 Hard Drive Replacement: passo 4, imagem 1 %32
    • Use the Phillips 00 screwdriver to remove the four 6.50mm screws on the sides of hard drive.
  5. Toshiba Satellite M55-S135 Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite M55-S135 Hard Drive Replacement: passo 5, imagem 2 %32
    • Use the Phillips 00 screwdriver to remove the other four 6.50mm screws on hard drive.
    • Remove the washer strips (the metal strips that the screws held down) from the hard drive.
  6. Toshiba Satellite M55-S135 Hard Drive Replacement: passo 6, imagem 1 %32
    • Pull the black tab away from the hard drive to separate the hard drive and the casing.
Conclusão
Matthew Trinh
Membro desde: 01/31/13
63 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 7-11, Maness Winter 2013 Membro de Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
Membros da 4
Autoria de 5 guias
2 comentários
I have a regular SATA 2.5 hard drive and it won't fit my M55-S1001. Is there something else I need??
Matthew Halbert - Responder
According to http://www.rakuten.com/prod/120gb-hard-d..., your hard drive is the right size. If it doesn't fit, check to see if the pins connect correctly and if your laptop accepts a SATA drive and not a PATA drive; this image can help http://www.laptopking.com/sata_identify.....
Next, check if you're inserting it correctly. I haven't experienced replacing the hard drive with the M55-S1001, but I assume it's the same method as the M55-S135 (though it could be different).
I'm unsure if there's anything else you would need besides the correct type of screwdriver to unlock the casing but I doubt it.
Matthew Trinh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 3,935
