Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will be referred to for other steps because disconnecting the power to your computer is crucial to do before working on it. There are two spring-loaded switches that lock the battery into place.
Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
Slide the unlock switch in the top left-hand corner to the left/unlock position.
