Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will demonstrate how to dismantle and replace components of your computers display (screen).
O que você precisa
Remove the keyboard. For keyboard removal instructions, see the keyboard guide here: Toshiba Satellite M45 Keyboard Replacement
Remove the black electrical tape covering the black-and-white antenna cable. There will be 2-3 pieces of tape.
After the tape has been removed, close the laptop display, flip the laptop over, and disconnect the black-and-white antenna cables from the WiFi Card.
For information about accessing the WiFi Card, see the WiFi Guide here: Toshiba Satellite M45 Wi-Fi Card Replacement
Once the antenna cables are disconnected from the modem card, flip the laptop back over and open the display.
Remove the two screws securing the display hinges with a #1 size Phillips head screwdriver. It is recommended to keep the screws in a small cup so that you don't lose them.
Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side.
3 outras pessoas executaram este guia.
