Ir para o conteúdo principal
Toshiba Satellite M35X-S114 RAM Replacement
O que você precisa
  1. Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: passo 1, imagem 1 %32 Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: passo 1, imagem 2 %32
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: passo 2, imagem 1 %32 Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: passo 2, imagem 2 %32
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: passo 3, imagem 1 %32 Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: passo 3, imagem 2 %32
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: passo 4, imagem 1 %32 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: passo 4, imagem 2 %32 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: passo 4, imagem 3 %32
    • Locate the RAM cover around the middle left-hand side of the device.
    • Locate the screw on the RAM cover.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
    • Carefully remove the RAM access hatch.
  5. Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: passo 5, imagem 1 %32 Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: passo 5, imagem 2 %32
    • Locate the four silver clips holding the RAM sticks.
    • There is a total of two RAM chips and four silver clips. Two silver clips hold one RAM stick. Remove one RAM stick at a time.
    • Use your fingers from separate hands to pull back the two silver clips away from the sides of the RAM stick.
    • Repeat this step for the other RAM stick.
  6. Toshiba Satellite M35X-S114 RAM Replacement: passo 6, imagem 1 %32
    • Gently pull the RAM stick out from its slot.
Conclusão
Christian Mayorga
Membro desde: 09/09/14
219 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team 2-4, Bruce Fall 2014 Membro de CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 457
