Ir para o conteúdo principal
Toshiba Satellite M35X-S114 Battery Replacement
  1. Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: passo 1, imagem 1 %32 Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: passo 1, imagem 2 %32
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: passo 2, imagem 1 %32 Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: passo 2, imagem 2 %32
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: passo 3, imagem 1 %32 Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: passo 3, imagem 2 %32
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
Conclusão
Nathan Jansen
Membro desde: 09/08/14
206 Reputação
Autoria de 1 guia
Equipe
CSU Fullerton, Team 2-4, Bruce Fall 2014 Membro de CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 378
