Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Unlatch the battery by pushing outward on both latches.
Remove the four rubber coverings at the corners of the screen frame to access the screws behind them.
Using a Phillips #0 screwdriver, remove the four screws at the corners of the screen frame.
Now you need to remove the bezel. This is the plastic frame around the screen. Gently pull it forward, and then upward to unsnap it from where it is connected at the hinges.
Turn the laptop around so that you can view the lid. Gently pull the lid away from the screen so that you can view the white clips near the base of the screen, as shown in the picture.
Un-clip the three connections to disconnect the wiring.
Remove the tape at the spots shown in the picture to detach the screen from the ribbon.
Turn the laptop so the screen faces you again. Remove this screw, and the corresponding screw on the left hand side.
Remove the four screws on the sides of the metal frame, located at the upper right and left, as well as the lower right and left.
