Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
  1. Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Remove the back panel.
  2. Locate the two clips holding the RAM chip in place. Apply pressure to each clip, pulling them away from the RAM. One end of the RAM will pop out.
    • Locate the two clips holding the RAM chip in place.
    • Apply pressure to each clip, pulling them away from the RAM.
    • One end of the RAM will pop out.
  3. Gently pull RAM out as shown. Gently pull RAM out as shown.
    • Gently pull RAM out as shown.
  4. To intall a new stick of RAM, carefully insert it into into the RAM slot.
    • To intall a new stick of RAM, carefully insert it into into the RAM slot.
    • Gently push down on the RAM chip until it snaps securely into place.
Conclusão
Michael Jensen
Membro desde: 18/04/2011
417 Reputação
6 Guias de autoria
Equipe
Cal Poly, Team 4-3, Regan Spring 2011 Membro de Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Membros
6 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 2,587
