Ir para o conteúdo principal
Toshiba Satellite M305D-S4829 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite M305D-S4829 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 4, imagem 2 %32
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 5, imagem 2 %32
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 6, imagem 1 %32 Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 6, imagem 2 %32
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 7, imagem 1 %32 Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 7, imagem 2 %32
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 8, imagem 1 %32
    • Your keyboard has now been successfully removed.
Conclusão
Michael Jensen
Membro desde: 04/18/11
425 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 4-3, Regan Spring 2011 Membro de Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,550
