Ir para o conteúdo principal
Toshiba Satellite L875D-S7210 RAM Replacement
O que você precisa
  1. Toshiba Satellite L875D-S7210 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Flip the laptop over and locate the screw beneath the left battery latch.
  2. Toshiba Satellite L875D-S7210 RAM Replacement: passo 2, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove the screw.
  3. Toshiba Satellite L875D-S7210 RAM Replacement: passo 3, imagem 1 %32 Toshiba Satellite L875D-S7210 RAM Replacement: passo 3, imagem 2 %32
    • Using a metal spudger, slip it into the groove and gently pry open the cover.
  4. Toshiba Satellite L875D-S7210 RAM Replacement: passo 4, imagem 1 %32
    • Locate the RAM card at the top left corner closest to the bottom of the battery.
  5. Toshiba Satellite L875D-S7210 RAM Replacement: passo 5, imagem 1 %32
    • Using two fingers, push the two levers outwards in opposite directions of each other to release the RAM card.
  6. Toshiba Satellite L875D-S7210 RAM Replacement: passo 6, imagem 1 %32
    • When done correctly, the RAM card should pop up like this.
  7. Toshiba Satellite L875D-S7210 RAM Replacement: passo 7, imagem 1 %32
    • Remove the existing RAM card and insert the your new RAM by snapping the RAM in place. Make sure the notch on your RAM card matches up with the slot.
Conclusão
Ian M Sloop
Membro desde: 10/20/18
667 Reputação
Autoria de 4 guias
Equipe
UC Davis, Team S7-G7, Lore Fall 2018 Membro de UC Davis, Team S7-G7, Lore Fall 2018
UCD-LORE-F18S7G7
4 Membros
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 441
