Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will inform readers on how to replace the screen which may stop working.
  1. Turn the laptop over to place it top down. Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate. Lift the back plate off the laptop, exposing the RAM and Hard Disk.
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  2. Turn the laptop face down to expose the back.
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  3. Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container. Push the latch on the right to the right to unlock the battery latch locking mechanism. Push the battery latch on the left to the left to unlock the battery.
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  4. With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery. The battery will come free.
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  5. Using a Phillips #0 screwdriver, remove the single 3mm screw. Using a Phillips #0 screwdriver, remove the single 3mm screw.
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  6. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  7. Rotate the laptop so that you have access to the optical drive. The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
  8. Unscrew the hard drive. There could be up to five 3mm screws - One on each corner of the hard drive, and one at one end of the hard drive, attaching the drive to the laptop's frame.
    • Unscrew the hard drive.
    • There could be up to five 3mm screws - One on each corner of the hard drive, and one at one end of the hard drive, attaching the drive to the laptop's frame.
    • Carefully push the hard drive away from its port. This should not require substantial force.
    • Lift the hard drive out.
    • Some hard drives have a plastic tab, which can be lifted from to remove the hard drive.
    • Otherwise, take hold of opposite sides of the hard drive and lift the drive straight up.
  9. Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver. Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
    • Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
    • Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
  10. Remove the two 5mm screws on the fan assembly using a Phillips #0 screwdriver. Remove the two 5mm screws on the fan assembly using a Phillips #0 screwdriver. Remove the two 5mm screws on the fan assembly using a Phillips #0 screwdriver.
    • Remove the two 5mm screws on the fan assembly using a Phillips #0 screwdriver.
  11. Unplug the fan's connection to the motherboard. Lift the fan from the laptop. Use a soft cloth to clean the dust away from where the fan was.
    • Unplug the fan's connection to the motherboard.
    • Lift the fan from the laptop.
    • Use a soft cloth to clean the dust away from where the fan was.
  12. Remove the two screws in each speaker using the Phillips #0 Screwdriver. Gently lift out the speakers out of the chassis. Gently lift out the speakers out of the chassis.
    • Remove the two screws in each speaker using the Phillips #0 Screwdriver.
    • Gently lift out the speakers out of the chassis.
  13. Using the Phillips #0 screwdriver, remove the 3mm retention screw from the display connector.
    • Using the Phillips #0 screwdriver, remove the 3mm retention screw from the display connector.
    • Unplug and remove the display connector by pulling the connector free.
  14. Remove the screen by removing two screws from both hinges using the #0 Phillips screwdriver. Once the hinges have been unscrewed separate the screen from the body containing the motherboard. Once the hinges have been unscrewed separate the screen from the body containing the motherboard.
    • Remove the screen by removing two screws from both hinges using the #0 Phillips screwdriver.
    • Once the hinges have been unscrewed separate the screen from the body containing the motherboard.
  15. The removed laptop screen should have the daughterboard and speakers attached to it via wires upon removal.
    • The removed laptop screen should have the daughterboard and speakers attached to it via wires upon removal.
Conclusão
Monte Roden
Membro desde: 14-02-2018
447 Reputação
4 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 181
