Introdução
This guide will inform readers on how to replace the screen which may stop working.
O que você precisa
Turn the laptop over to place it top down.
Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
Lift the back plate off the laptop, exposing the RAM and Hard Disk.
Unscrew the hard drive.
Carefully push the hard drive away from its port. This should not require substantial force.
Lift the hard drive out.
Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
Remove the two screws in each speaker using the Phillips #0 Screwdriver.
Gently lift out the speakers out of the chassis.
