Ir para o conteúdo principal
Toshiba Satellite L775D-S7340 Optical Disk Drive Replacement
O que você precisa
  1. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: passo 2, imagem 1 %32
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: passo 3, imagem 1 %32
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement, Optical Disk Drive: passo 4, imagem 1 %32
    • Remove the (mm) screw in between the two white manufacturer’s stickers using the Phillips #1 screwdriver.
  5. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: passo 5, imagem 1 %32
    • Gently slide the optical disk drive out of the computer.
Conclusão
Madeline Park
Membro desde: 09/21/17
441 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 210
