Introdução
This guide will show you how to remove and replace the keyboard.
O que você precisa
Make sure the laptop is unplugged and powered off.
Locate the battery latches on the underside of the laptop.
Pry up the thin narrow strip of facing above the keyboard using the opening tool.
Remove the four screws securing the keyboard using the T4 Torx screwdriver,
Uma outra pessoa concluiu este guia.
Um comentário
I need to know how to change a plasma for a Toshiba Satellite L775D-S7340
